Get into your Word 2010 options through File, Options. Select Advanced from the options listed on the right then scroll down to the
Display section about halfway down.
You should find options for both Show horizontal scroll bar and
Show vertical scroll bar within that section.
Remember to OK on the way out in order that you save your changes.
