Use VBA Excel to select 8 non-specific blank cells in a column
Hi
I'm trying to find a way to use VBA in excel to select a column of 8 blank cells starting with (and including) a changing active cell.
To expand a little, the idea is to find the first blank cell in a column, select 8 cells down including that cell and paste the same thing into all the cells.
I'm hoping to make this part of a ' for each' loop
I'm still learning VBA so any help will be useful
Thank you,
Dan
hi
if any one else is searching for this I have found one way
Dim first_cell As String
Dim last_Cell As String
If IsEmpty(ActiveCell) Then
first_cell = ActiveCell.Address 'finds address of first cell eg. A1
last_Cell = ActiveCell.Offset(7, 0).Address 'finds address of last cell eg. A8
Range(first_cell, last_Cell).Select
End If
I don't know if there is a better way, but this seems to work
Last updated March 30, 2025 Views 53 Applies to:
