Substitution for SUMIFS function for MS Excel 2003 version
Good Day to all!
Do you have any suggestion for a substitution of the SUMIFS function for the MS Excel 2003 version.
Thanks!
i earlier tried to use a B:B, C:C, D:D for this function but it showed =!value.
SUMPRODUCT() doesn't skip over text values when adding numbers like a SUM() function will do so any text such as column header labels would have produced the #VALUE! errors. You can get around this with an array formula like,
=SUM(IF(Sheet1!B:B=$E14,IF(Sheet1!C:C=$F14,Sheet1!D:D)))
... which is finalized with Ctrl+Shift+Enter↵ rather than just Enter↵.
... and then i wanted the TOTAL # of students will be added having the COURSES AND MAJOR as reference.  This will be on another sheet.
A SUMPRODUCT() formula using the Course and Major as criteria should be sufficient.
The formula in D14 is,
=SUMPRODUCT(($B$5:$B$11=$B14)*($C$5:$C$11=$C14)*($D$5:$D$11))
... which can be filled down as necessary to accomadate the values in columns B and C. This style of formula will work just as well on another worksheet as long as the range references include the worksheet in the addresses. Something like,
=SUMPRODUCT((Sheet1!$B$5:$B$11=$B14)*(Sheet1!$C$5:$C$11=$C14)*(Sheet1!$D$5:$D$11))
Last updated September 7, 2020 Views 6,580 Applies to:
