Is there something specific I need to do when creating more than one VBA code on a worksheet?
It seems that when I have more than one code - only one or the other wants to work for me.
Sheri
April 9, 2024
Click here to learn more 💡
May 10, 2024
Sheri
·Was this reply helpful?
Thanks Kevin,
With what I have so far, where would I place what you typed?
This is what I have right now - which works great to hide rows.
Private Sub Worksheet_Change(ByVal Target As Range)
If Not Intersect(Range("F8"), Target) Is Nothing Then
Application.EnableEvents = False
Range("A9:A17").EntireRow.Hidden = (UCase(Range("F8")) = "NO")
Application.EnableEvents = True
End If
If Not Intersect(Range("F18"), Target) Is Nothing Then
Range("A19:A30").EntireRow.Hidden = (UCase(Range("F18")) = "NO")
End If
End Sub
This is what I want to add, which does not work when I add it to the above codes:
If Not Intersect(Target, Range("F5")) Is Nothing Then
If Target.Value = "NO" Then
Range("F9").Value = "N/A"
Else
Range("F9").Value = ""
End If
End If
Can you help?
Sheri
