Right Alignment Problem in Table of Contents
I have a difficulty with Table of Contents in Word 2016 for Mac. The page numbers in Table of Contents are not right aligned although they are set to be so. Attached image shows the problem.
Page numbers are supposed to be right aligned. They should have the same intent with "Page" text in Table of Contents.
The problem occured after I changed the left margin of the page from 1.5 inch to 1.0 inch. The same problem occurred for "List of Tables", and "List of Figures" pages too, but they became normal (right aligned) after I updated the content of them.
Thank you in advance for your helps!
  1. Have you checked in styles window  and open the style the documents it using.
  2. Then Check the settings for the right tab stop.
Then I would for the  Page Item, set it for the same margins. To do so, on the Home Tab on the Ribbon:
  1. Go to the tab Button.
  2. Click until you first see a right facing Tab stop.
  3. Now mouse over close to desire position on the Ruler.
  4. Finally drag the tab into final position so that the "|"  line you see, is just at the edge of the V in IV.
_________
Disclaimer:
The questions, discussions, opinions, replies & answers I create, are solely mine and mine alone, and do not reflect upon my position as a Community Moderator.
If my reply has helped, mark accordingly - Helpful or Answer
Phillip M. Jones, C.E.T.
Last updated April 14, 2025 Views 11,142 Applies to:
