Proofing Language Keeps Changing - Solutions - How can I keep my proofing language from changing? Spelling Checker doesn't work!
Scope: All desktop versions of Word (Mac and Windows)
Technical Level: Beginner - Intermediate
Summary:
The question posted here is: How can I keep my proofing language changing (often to English US)? or The Spelling Checker doesn't work!
The basic answer is that unless you do your work on an isolated computer and do not paste into your document, you cannot. However, there are steps you can take that will make things go much more smoothly.
This article first discusses four things to do in your system and in your document to make proofing language work for you.
Then three macros are provided with instructions for making deeper-level changes. Those macros can also be used for problems with "Do Not Check Spelling or Grammar" issues.
I urge anyone running into problems with the spelling checker to read Mastering the Spelling Checker by Suzanne Barnhill, MVP . As far as I know, that is the best discussion of problems and solutions that involve that tool.
Detail:
First, if possible, your Operating System (Windows/MacOS) regional language settings should match your primary language setting in Word.
Second: Become familiar with the Proofing Language as a concept and with the Proofing Language Dialog
The "proofing language" is a key to several Word features including spelling and grammar and AutoCorrect. It is not an application-wide setting nor even a document setting; it is set at the character level! It is set at the character level in every document.
Status Bar (This  part about the Status Bar may only apply to Windows versions.)
You can display the proofing language for a particular place in a document on the Status Bar. (Windows) If this is not showing there, right-click and add it.
Right-clicking on the Status Bar lets you check or uncheck what you want there.
Because the proofing language is character-level formatting, it can be imported when you paste text from other documents or from the Internet (or within a document). It can be in your Styles.
Third, make sure that you turn off the proofing option to detect language automatically. Word is bad at this and terrible when it comes to distinguishing the spelling in various forms of English (or other languages with multiple spelling versions).
There are two checkboxes at the bottom of the dialog. Both should be blank (empty).
On this dialog, the settings for what the proofing language is and for checking spelling are grammar are at the character level.
On the other hand, the setting for detecting language automatically is a system setting that applies to all documents that you open until it is changed.
Fourth: The simplest thing to do for an immediate fix to a document is to select all the text in your document and apply the correct proofing language. Ctrl+A and then Reviewing tab > Language > Proofing Language and then select the correct language. (Clicking on the language in the status bar will take you directly here.
Also, make sure the box "Do not check Spelling or Grammar" is not checked. If misspelled words are not being flagged, this is almost always the problem.
For a single document with problems, this solution of selecting and changing will give a quick fix.
Again, it is important that you keep in mind that the proofing language can be in any text that you paste in!
Macros can be used for tougher problems.
  • Proofing language in headers/footers, textboxes, etc. within a document
  • Proofing language contained in Styles in the document
  • Proofing language contained in Styles in the Normal template.
Here are three macros to address these problem-. Although they are set for English UK or English AUS, you can change that. See Language IDs in VBA to find the language ID you would want if not English UK.
If you are just dealing with your language setting changing to "Do Not Check Spelling or Grammar" you can delete or comment out the lines dealing with the proofing language.
The first one is for an individual document to set the proofing language for all text to English US.
  • Again, change the language ID if you want a different language.
  • Also turns off any "do not check attribute. - Delete or comment out line if you do not want this.
  • If you are just dealing with "do not check" delete or comment out the lines with the language attribute. These are marked below.
Sub ProofingLanguageEnglishUSAllStory()    ' based on field updater by Greg Maxey
    ' https://gregmaxey.com/word_tip_pages/word_fields.html
    ' Charles Kenyon 6 November 2018
    ' https://answers.microsoft.com/en-us/msoffice/forum/all/force-all-documents-to-be-edited-in-uk-english/df6d1f8e-5426-49d9-bea0-5620d0208294
    ' Changes proofing language to English US in all stories of document
    ' Language IDs https://docs.microsoft.com/en-us/office/vba/api/word.wdlanguageid
    Dim rngStory As Word.range
    Dim lngValidate As Long ' do not know purpose of this
    Dim oShp As Shape
    lngValidate = ActiveDocument.Sections(1).Headers(1).range.StoryType
    For Each rngStory In ActiveDocument.StoryRanges
      'Iterate through all linked stories
      Do
        On Error Resume Next
        rngStory.LanguageID = wdEnglishUS  ' delete or comment out if you do not want to change the language ID
        rngStory.NoProofing = False        Select Case rngStory.StoryType
          Case 6, 7, 8, 9, 10, 11
            If rngStory.ShapeRange.Count > 0 Then
              For Each oShp In rngStory.ShapeRange
                If oShp.TextFrame.HasText Then
                   ' Comment out or delete the next line if you do not want to change proofing language
                   oShp.TextFrame.TextRange.LanguageID = wdEnglishUS  ' delete or comment out if you do not want to change the language ID
                   ' Comment out or delete the next line if you do not want to change the "no proofing" setting
                   oShp.TextFrame.TextRange.NoProofing = False
                End If
              Next
            End If
          Case Else
            'Do Nothing
        End Select
        On Error GoTo -1
        'Get next linked story (if any)
        Set rngStory = rngStory.NextStoryRange
      Loop Until rngStory Is Nothing
      Next
End Sub
The second one is to change the proofing language of allStyles to English UK:
  • Again, change the language ID for a different language
  • This also makes sure that "do not check Spelling or Grammar" is not checked - you can delete or comment out this line if you want
Sub StyleEnglishUK()
'   Written 21 March 2018
'   Charles Kenyon
'   Intended to set all styles to EnglishUK, proofing, not automatically update
    Dim aStyle As Style
    On Error Resume Next ' Some styles have no language attribute and will give an error
    For Each aStyle In ActiveDocument.Styles
        Select Case aStyle.NameLocal
            Case "TOC 1", "TOC 2", "TOC 3", "TOC 4", "TOC 5", "TOC 6", "TOC 7", "TOC 8", "TOC 9", "Table of Figures", "Table of Authorities"
                Let aStyle.AutomaticallyUpdate = True
            Case Else
                Let aStyle.AutomaticallyUpdate = False
        End Select
        Let aStyle.LanguageID = wdEnglishUK  ' delete or comment out if you do not want to change the language ID
        Let aStyle.NoProofing = False
    Next aStyle
    Let ActiveDocument.UpdateStylesOnOpen = False ' For information on using this line, see:
'       http://www.shaunakelly.com/word/sharing/willmyformatchange.html
    On Error GoTo -1
End Sub
If the styles in your normal template are off, here is one for the normal template: English Australian
Sub StyleEnglishAUSNormalTemplate()
'   Written 27 September 2019
'   Charles Kenyon
'   Intended to set all styles in Normal template to EnglishAUS, proofing, not automatitically update
'   Use right after opening Word
    Application.ScreenUpdating = False
    Application.NormalTemplate.OpenAsDocument
    Dim aStyle As Style
            Case Else
        End Select
        Let aStyle.LanguageID = wdEnglishAUS  ' delete or comment out if you do not want to change the language ID
        Let aStyle.NoProofing = False   ' also turn on spelling and grammar checking
    Next aStyle
' For information on using the above line, see:
    ActiveDocument.Close SaveChanges:=True
    Let Application.ScreenUpdating = True
    Application.ScreenRefresh
    MsgBox Title:="All done!", Prompt:="Proofing Language in all styles in the Normal template set to English Australian."
    On Error GoTo -1
End Sub
Note that the last two macros on styles turn on spelling and grammar checking in all styles as well as change the language. If you do not want that to happen, remove the line:
or go back to the styles where you want spell-checking turned off after you've run the macros. Likewise the language about automatically updating styles.
Here's how to use a macro found in this forum or on another webpage:
For PC macro installation:
For Mac macro installation & usage instructions, see:
There is a Microsoft Help page on this. I disagree with some of its points but it handles some things more thoroughly than I can here.
See also Bob Korchock's excellent analysis in this thread. He says pretty much the same thing but uses different language and has a Mac perspective.
Was this article helpful?
Thank you, this is very helpful.
Was this comment helpful?
How satisfied are you with this comment?
When the above does not help...
See Dave Rado's remarks in this thread. He wanted English UK and English US kept appearing.
Dave is a very knowledgeable and experienced Word user. He is the author of numerous MVP FAQ articles and I have learned much from him.
UK English was my default language both in the Windows Region settings and in the Office Language settings.
But I've found a clue in an old Graham Mayor post that has enabled me to fix the problem.
Although I can't delete US English from the enabled languages list via the Microsoft Office 2007 Language Settings - when I try, the dialog says it had been removed but then it reappears again the next time I open the dialog - I've discovered that I can remove US English from the Preferred Languages list in the Windows Region settings and this has fixed the problem.
But it was very difficult to find where you can remove it. In the end I went to Start + Settings + Control Panel + Region, and then in the Region dialog I clicked Language Preferences, and then under Preferred Languages I moved UK English to the top of the list and was then able to remove US English - and now Word is working as it should.
Volunteering to "pay forward" to return help I've received in the Microsoft user community.]
Charles Kenyon
Sun Prairie, Wisconsin
wordfaq[at]addbalance[dot]com
Legal website: http://addbalance.com
3 people found this comment helpful
Thanks for this, it has solved a continuing problem that I've had. You'd normally expect a local setting (e.g. for a language in Word) to override one set at a more general and higher level (the operating system). So from now on I must remember that Microsoft S/w is designed so that everything is controlled from the top down.
1 person found this comment helpful
Just try hitting <Windows Key>+<Space Bar>
______
I'm French speaking but have my system user interface language set to English
So I used to have a similar problem with Outlook Desktop; when I type an email,, proofing language kept switching to English, even though I had set the document proofing language to French..
Solution is to set the input method language to French, by hitting <Windows Key>+<Space bar>.  (or via the System Tray). Your "input method" language overrides the proofing language set in your current document.
If you "tell" Windows : "I'm currently typing in language <X>", then the app (Outlook or Word or whatever) quite logically sets the proofing language of your input to <X>.
[Charles Kenyon supplement: The Windows Key + SpaceBar is a default keyboard shortcut to switch keyboard setups. If you have multiple languages, make sure it selects the one you want. If you only have two, it will toggle.]
Thank you for the additional method. This is not really the subject of this Article, though, even if related.
I can confirm that this changes the proofing language in which you are typing in Word as well as the keyboard.
However, this will not change existing text in a document. The language setting for that text remains whatever was used when it was typed unless one of the other methods is used.
Charles Kenyon
MS software is not designed so everything is controlled from the top down. This is an anomaly.
Generally, at least in Word, the lowest level is what controls.
The character-level formatting for language will overrule operating system, application, and document settings.
In this anomalous instance, the Operating System settings can overrule the [default] application settings, but not the character-level settings.
Charles Kenyon
To add to what Charles has said, I think it would be fair to say that the operating system language can override the default language setting in Word/Office.
Stefan Blom
Office Apps & Services (Word) MVP
Volunteer Moderator (Office)
Please note that I do not work for Microsoft
MVP program info: https://mvp.microsoft.com/
Forum Article Info
Last updated June 13, 2021 Views 11,293 Applies to:
