Problem inserting word document into a word document
When I try to insert a word document into another word document the space for my data is very limited. Almost 2 inches and it wraps instead of covering the whole page. Any ideas?
You'll find the icon for inserting objects in the Text group of the Insert tab on the ribbon:
When you click the arrow on the Object icon, you'll see a drop down menu. Click the Text from File command to display the Insert File dialog box. After having selected the document you want to insert, click the arrow on the Insert button and choose Insert
as Link. See screen shot below.
Inserting a document as a link will create an INCLUDETEXT field that references the inserted file. You can update the field so that it reflects subsequent changes made in the source file. Also, you can save changes made in the field back to the source file
with Ctrl+Shift+F7.
Stefan Blom MS 365 Word MVP since 2005 Volunteer Moderator MS 365, Win 11 Pro ~~~ Note that I do not work for Microsoft https://mvp.microsoft.com/ ~~~ Please specify Word version & OS in your question
