I am experiencing a bizarre issue in word 365 web where the page breaks aren't clear or visible. I attached a screenshot of how they look to me. Normally there is a space between the pages.
On its own, this wouldn't bother me, but the pages also don't behave normally. As you can see, this page divides my content. In the past, I would press enter until the section appears at the top of the next page instead of half way down a page. This used to work seamlessly in previous versions of word, but when I try to do it in the current web version of word, the page division in my screenshot simply moves to a new place place. This also results in abnormally long pages, or pages with different lengths. When I go into reader mode to see what page the content is on, it often doesn't match what is shown in the edit screen So for example, I might put a new paragraph below that division line indicating the next page, but when I go into reader, that paragraph would be half way down the page instead. The only way I have found to get around this is to create manual page breaks which results in some pages being a few inches long, and others being like 10 inches long.
As this is a web version of word, there is no "print layout view" clearly labeled, and there is no file menu so I can't go into File > Options > Display to show white space between pages, or to change the view. I can only toggle between edit mode and reader view, and only reader view shows me the pages, but without the ability to edit them - meaning that it is essentially useless to me. Also worth mentioning, I manually selected "narrow" margins and "letter" size in layout.
Is there a way to use pages normally in edit mode in the web version of word?
