Hello everyone!
This is the second time this has happened to one of my team members, and we are puzzled.
We use OneDrive for Business on an Office 365 online subscription, and the whole team shares and works in a common folder which is housed in and shared from a single user's account.
For the second time, this shared folder has just disappeared from a team member's Windows 10 File Explorer. The OneDrive client appears to have just disconnected itself from the cloud. The user has NOT disconnected or de-linked the OneDrive client herself. When we restart the OneDrive desktop client, we have to re-sync her private (personal) OneDrive, and then we have to again try to add in the OneDrive for Business shared folder, as if it had never been on her laptop before.
The first time we tried to re-sync her laptop with the shared folder, it said "A [Common Folder] already exists in your [OneDrive for Business] folder," with a further warning that "If you choose this location for your [Common Folder], files in this folder will be merged with files in the cloud."
We went ahead and re-synced to the same Common Folder location on the cloud--because the Common Folder was NOT showing up in her laptop's File Explorer. Well...it must be there invisibly, because it did indeed wreak havoc to our then newly re-organized directories.
This time around, the same thing is happening. For some unknown reason, OneDrive for Business shared folder has disappeared from her File Explorer (as described above). When we try to just re-sync with the shared folder, it says that "A [Common Folder] already exists in your [OneDrive for Business] folder," and warns that the (invisible) files on her laptop will be merged with files in the cloud.
First, why might OneDrive for Business shared folders be disappearing or delinking from her File Explorer/laptop? She has been traveling abroad quite a bit, but I don't see why that would cause the connection to disappear.
Second, how do we re-sync her laptop with the cloud shared folder without creating havoc as before? The shared folder isn't visible on her laptop, so it's not like we could just delete that and start from scratch. It's not there! But apparently it is...
Thanks for any help!
Erica
