Dear Charalambous,
Thank you for posting in Microsoft Community. It will be a pleasure working with you,
Sorry to hear that you are having trouble syncing your OneDrive for Business files and folders. There are some possible causes and solutions for this issue.
One possible cause is that you have exceeded the sync limits for OneDrive for Business. According to the Microsoft documentation, the maximum number of files that can be synced for a library is 300,000. However, this limit may vary depending on factors such as hardware configuration, network bandwidth, and file types. Therefore, it is recommended to keep the number of files well below the limit to avoid sync problems.
Another possible cause is that you are using an outdated version of the OneDrive for Business sync app. You should make sure that you have the latest version of the app installed on your computer. You can check for updates by following these steps:
On a PC, you should see a white or blue OneDrive cloud icon in the notification area, at the far right of the taskbar.
Right-click the OneDrive icon and select Settings.
On the About tab, select Check for updates.
A third possible cause is that there are some sync conflicts or errors between your local and server copies of files. You can resolve these conflicts or errors by following these steps3:
Right-click the OneDrive icon and select View sync problems.
An error dialog box opens that describes any current sync problems and suggests actions you can take to fix them.
Follow the instructions in the dialog box to resolve each sync problem.
If none of these solutions work, you can try to repair the sync connection for your OneDrive for Business libraries by following these steps:
On the Account tab, select Unlink this PC.
Sign in to your account again and select the libraries you want to sync.
I hope this helps you fix your OneDrive for Business sync issue.
To notify us and have us get back to you, simply reply to this post.
Thank you,
Microsoft Community
