office 365 word will not start
I have restarted the computer,  reinstalled office 365, removed several HKEY_CLASSES_ROOT files as well as removed HKEY_LOCAL_MACHINE FILES.
The system comes up and says that that it failed to shut down properly and ask about opening in safe mode.  I have tried it both ways. In safe mode the screen goes to the Starting.... yet does not go any further.  In safe mode it says that it had a error.
Please help.
I'd suggest doing an online repair of the installation.
The instructions to follow to do this are here:
https://support.office.com/en-us/article/repair...
Hi Tina, follow these steps to perform a full repair of your Office installation . . .
Open Control Panel - Programs and Features
Click Microsoft Office in the list of installed applications
At the top, click 'Change'
On the resulting dialog, click 'Repair' - choose the online repair, it is a comprehensive fix
That should fix any issues with your Office Installation . . .
___________________________________________________________________
Power to the Developer!
MSI GV72 - 17.3", i7-8750H (Hex Core), 32GB DDR4, 4GB GeForce GTX 1050 Ti, 256GB NVMe M2, 2TB HDD
If repair do no work try using this tool
https://www.microsoft.com/en-us/download/detail...
Volunteer, No Microsoft Agent.
Feel free to pick a rate if your question is resolved.
Hello Tina!
The symptoms you've described seems to be related to this:
Microsoft Apps Crashing
https://answers.microsoft.com/en-us/msoffice/fo...
Try this: Open the register editor and delete this keys :
(In the search box on the taskbar, type regedit. )
HKEY_CURRENT_USER\Software\Microsoft\Office\16.0\Common\Licensing\CurrentSkuIdForApp
HKEY_CURRENT_USER\Software\Microsoft\Office\16.0\Common\Experiment
HKEY_CURRENT_USER\Software\Microsoft\Office\16.0\Common\ExperimentEcs
HKEY_CURRENT_USER\Software\Microsoft\Office\16.0\Common\ExperimentTas
Hope it helps !
Germain N.
Last updated November 12, 2022 Views 5,376 Applies to:
