Numeric Picture Switch (\#) Issue
I am trying to add four numeric picture switches (\#) to mail merge fields in Word. Specifically I need to remove the decimal places. The code I am using is "{MERGEFIELD M_1109 \# $,0}" When I add the switch to the end of two mergefields all works as needed. When I add the switch to three mergefields they all break with an error saying the data source could not be found. (The two that work are interchangeable between the three.) And the fourth mergefield never works with the switch.
Any ideas?
Thank you!!
He's looking for the data source: the file that contains the data that are merged into the mail merge main document, the file that is generated by Encompass.
Microsoft MVP (Word) since 1999
Fairhope, Alabama USA
http://ssbarnhill.com
http://wordfaqs.ssbarnhill.com
Screen shots captured with TechSmith's Snagit
Last updated October 5, 2021 Views 927 Applies to:
