I run a mail server on a static IP assigned by AT&T business. The mail server is network blocked when attempting to send to outlook.com virtual domains. The mail server attempted to send a message to enphaseenergy.com which was not successful.
syslog:Sep 2 12:05:55 mail2 postfix/smtp[29924]: 4H0lgw1FdXz1LCw3: to=<*** Email address is removed for privacy ***>, relay=none, delay=1063, delays=1003/0.02/60/0, dsn=4.4.1, status=deferred (connect to enphaseenergy-com.mail.protection.outlook.com[104.47.51.110]:25: Connection timed out)
I send a second mail to this *** Email address is removed for privacy *** from a Gmail address which is successful.
From the mail server, I attempted to connect direct to the mail server at enphaseenergy-com.mail.protection.outlook.com. This connection also timed out.
toor@mail:/var/log# telnet enphaseenergy-com.mail.protection.outlook.com 25
Trying 104.47.56.110...
telnet: Unable to connect to remote host: Connection timed out
I found an old post from 2014 of several others that are reporting being blocked
This seems to be a problem for others as there are even more posts about this issue throughout the years.
I did discover a way to be "delisted" by following this
https://support.live.com/eform.aspx?productKey=edfsmsbl3&ct=eformts&scrx=1
However, when I do, I see an immediate block by what I believe is a CDN
Service Unavailable - DNS failureThe server is temporarily unable to service your request. Please try again later.
Reference #11.47761cb8.1630600765.1b8c5e3
My static IP is a subnet of a registered business network range for AT&T. My mail server has proper forward and reverse lookups as well as SPF, DMARC, and DKIM TXT records.
What's the proper process for delisting?
Also how to obtain a better reputation score so that my personal email to others aren't auto flagged as Spam? We are two people sending emails in very low volume. Because of our low volume, our mail does not get scored correctly with a reputation score because there is so little to compare to. The algorithm for auto SPAM does not work well for low volume domain email addresses.
***Moved from Outlook.com/Security, privacy, and accounts/Other***
