How to use an A1,A2,A3 sequence for one level in a multi level list in word
Anyone know how to configure word to allow this kind of a list format using the multi level list feature:?
A.   First item on level one of a list
A1.
A2.
A3.
B.  Second item on level one of a list
B1.
B2.
B3.
B4.
C. Third item on level one of a list
C1.
c2.
Hi John,
Step by step instructions for setting up your numbering can be found here:
How to create numbered headings or outline numbering in Ribbon Versions of Word by Shauna Kelly
This method may seem a bit of work but not using it for important work is asking for trouble. Once you have it set, you can save a template with it and use that template for new documents where you need good numbering that can survive editing.
I hope this information helps. Please let me know if you have any more questions or require further help.
Regards
Charles Kenyon
Attorney at Law
Madison, Wisconsin
wordfaq[at]addbalance[dot]com
The Importance of Styles in Microsoft Word
https://www.addbalance.com/usersguide/styles.htm#Overview
Last updated February 10, 2025 Views 10,782 Applies to:
