How to sort {9.2.7, 7.0.10, 10.0.10} kind of values in excel
June 10, 2024
Excel Forum Top Contributors:
HansV MVP - Ashish Mathur - Andreas Killer - Jim_ Gordon - Rich~M ✅
You have to split your text to number parts, e.g.:
Now you can sort all data, by a,b,c and get the desired result. There are several ways to perform the split, I suggest to copy column A to B, then use "Text to Columns".
Andreas.
A Python function can sort it more directly, but it's limited (AFAIK) to only 3 levels. (as per your example data)
You can easily complicate the whole thing:
Index | Header | Order |
7.0.10 | a | 1 |
7.2.1 | d | 2 |
7.2 | c | 3 |
7.10.0 | e | 4 |
9.2.7 | f | 5 |
10.0.10 | g | 6 |
11.2.3.5 | j | 7 |
11.2.3.4.7 | i | 8 |
11.2.3.4 | h | 9 |
7.0.10.1 | b | 10 |
Sort all data based on index column. This is the correct result:
7.0.10 | a | 1 |
7.0.10.1 | b | 10 |
7.2 | c | 3 |
7.2.1 | d | 2 |
7.10.0 | e | 4 |
9.2.7 | f | 5 |
10.0.10 | g | 6 |
11.2.3.4 | h | 9 |
11.2.3.5 | j | 7 |
The point is that there is no simple workaround, we must split the Index by . to get the numbers then we can sort the data by that numbers. However you do it.
Andreas.
if with sql:
select * from basic_order_by_natural order by colIndex[0:0] COLLATE NATURAL_CMP;
https://b23.tv/ojqtPWF
Excel 365 Pro Plus with Power Pivot and Power Query.
Sort Dewey Decimal System.
Example as applied to a BOM to aggregate costs in a PivotTable.
Last updated February 12, 2024 Views 118 Applies to:
