I have the following Excel pivot table:
This Pivot Table is build from the following table called "Systems"
I add a Calendar Table into the model too
Following with the above Pivot Table picture, I have tried to write the below DAX measure to calculate the Running Total values (Column E in the above Pivot Table) related with column "Total".
As you can see in the above Pivot Table the RTotal DAX measure applied in column E didn't work well.
So what do I need???
1 ) I would like ask you about DAX measures the get the columns "Yearly RTotal" (accumulates the year results of "Total" only) and "AllTime RTotal" (accumulates the entire pivot table results of "Total") in the below Pivot Table
2) Moreover I need that these DAX measures work well when I try to filter by "Year" column too.
For example, if I filter for 2022 and 2023 years, I would like to get the following Pivot Table
