How to remove side column numbers and top letters in Excel?
How do you remove side column numbers and top column letters A,B,C,D and so on? I do not want to see them at all nor print them. This may be a simple question to most but not to me. thanks for your help.
I've moved you inquiry from the
Feedback forum to
Office, Excel. The answer to your question resides within the View and
Page Setup options and these are available within difference areas for different versions of Excel.
As far as viewing the row and column headers, for Excel 2007 or Excel 2010, uncheck
Headings from the View tab's Show/Hide group.
To remove the row and column headers from printed output in Excel 2007 or 2010, click the small
Page Setup arrow in the lower left of the Page Setup tab's Page Setup group. This is a small arrow-like button to teh right of the words Page Setup. When the Page Setup dialog opens up, go to the
Sheet tab and uncheck Row and column headings from the middle
Print group.
If you need more help, post back with a progress report and let us know what version of Excel and Windows you are using.
391 people found this reply helpful
