How to join 2 files in Excel using SQL
I have 3 files that I need to join to build a report. For now, I'm trying to join the first 2 files. I'm able to successfully execute each query, yet when I join them, it fails, raising an error: "An error occurred after the connection was established. Error number: -2147217900 Error Description: Syntax error in FROM clause.
I am running this under Windows 11 Pro version 10.0.22631 Build 22631, Office 365, Excel for MS 365 MSO (Version 2402 Build 16.0.17328.20282) 64-Bit, in an Excel macro using VBA code.
'This works
Sql1 = "select m.Hostname, m.[IP Address], m.[OS Type], m.Vendor, m.Name, m.Version " & _
",m.Hostname + m.Name as MasterHostnameName " & _
",iif(instr(1,m.hostname,'.') > 0, mid(m.hostname,1,instr(1,m.hostname,'.')-1), m.hostname) as MasterHostname" & _
" from [Raw Data$] as m in '" & ActiveWorkbook.Path & "\MasterFile.xlsx' 'Excel 12.0 Xml;HDR=YES'"
'This works
Sql2 = "select p.Hostname, p.Name " & _
",p.Hostname + p.Name as PowerBiHostnameName " & _
",p.[Asset Type] " & _
",p.Vendor " & _
" from [Export$] as p in '" & ActiveWorkbook.Path & "\PowerBi.xlsx' 'Excel 12.0 Xml;HDR=YES' " & _
" where p.[Asset Type] <> 'Client' " & _
" and p.Vendor like 'myvendor' "
'This does not work
SqlJ1 = "select m.Hostname, m.[IP Address], m.[OS Type], m.Vendor, m.Name, m.Version " & _
" from [Raw Data$] as m in '" & ActiveWorkbook.Path & "\MasterFile.xlsx' 'Excel 12.0 Xml;HDR=YES'" & _
" left outer join (select p.Hostname, p.Name " & _
",p.Vendor " & _
" and p.Vendor like 'myvendor' " & _
") as pp " & _
" on pp.Hostname = m.Hostname " & _
" and pp.Name = m.Name "
'This does not work
SqlJ2 = "select m.Hostname, m.[IP Address], m.[OS Type], m.Vendor, m.Name, m.Version, " & _
",r.Hostname + r.Name as PowerBiHostnameName " & _
",r.[Asset Type] " & _
",r.Vendor " & _
" left outer join [Export$] as p in '" & ActiveWorkbook.Path & "\PowerBi.xlsx' 'Excel 12.0 Xml;HDR=YES' " & _
" on p.Hostname = m.Hostname " & _
" and p.Name = m.Name " & _
Here is an example of MasterFile.xlsx
Here is an example of PowerBi.xlsx
Hello there, In your SqlJ1 and SqlJ2 queries, it seems you're trying to perform a LEFT OUTER JOIN between the "Raw Data" sheet from "MasterFile.xlsx" and the "Export" sheet from "PowerBi.xlsx", Below are some potential issues and corrections for your SQL queries: 1)Alias Naming Convention: In your LEFT OUTER JOIN, ensure that you're using the correct aliases for the tables (m and p), and also ensure that you're referencing the correct columns in the ON clause. 2)Column Ambiguity: Make sure that column names referenced in the SELECT statement are not ambiguous, especially if they exist in both tables being joined. 3)Formatting: Check for any formatting errors such as missing spaces or extra spaces that might cause syntax errors. Let's revise your SQL queries accordingly: For SqlJ1: SqlJ1 = "SELECT m.Hostname, m.[IP Address], m.[OS Type], m.Vendor, m.Name, m.Version, " & _ "m.Hostname + m.Name as MasterHostnameName, " & _ "iif(instr(1,m.hostname,'.') > 0, mid(m.hostname,1,instr(1,m.hostname,'.') -1), m.hostname) as MasterHostname " & _ "FROM [Raw Data$] AS m IN '" & ActiveWorkbook.Path & "\MasterFile.xlsx' 'Excel 12.0 Xml;HDR=YES' " & _ "LEFT JOIN (SELECT p.Hostname, p.Name, p.[Asset Type], p.Vendor " & _ "FROM [Export$] AS p IN '" & ActiveWorkbook.Path & "\PowerBi.xlsx' 'Excel 12.0 Xml;HDR=YES' " & _ "WHERE p.[Asset Type] <> 'Client' AND p.Vendor LIKE 'myvendor') AS pp " & _ "ON pp. Hostname = m.Hostname AND pp. Name = m.Name" For SqlJ2: SqlJ2 = "SELECT m.Hostname, m.[IP Address], m.[OS Type], m.Vendor, m.Name, m.Version, " & _ "m.Hostname + m.Name as MasterHostnameName, " & _ "iif(instr(1,m.hostname,'.') > 0, mid(m.hostname,1,instr(1,m.hostname,'.') -1), m.hostname) as MasterHostname, " & _ "p.Hostname + p.Name as PowerBiHostnameName, p.[Asset Type], p.Vendor " & _ "FROM [Raw Data$] AS m IN '" & ActiveWorkbook.Path & "\MasterFile.xlsx' 'Excel 12.0 Xml;HDR=YES' " & _ "LEFT JOIN [Export$] AS p IN '" & ActiveWorkbook.Path & "\PowerBi.xlsx' 'Excel 12.0 Xml;HDR=YES' " & _ "ON p.Hostname = m.Hostname AND p.Name = m.Name " & _ "WHERE p.[Asset Type] <> 'Client' AND p.Vendor LIKE 'myvendor'" These revised queries ensure that the tables are properly aliased, and the JOIN conditions and column references are correct. Please do give these revised queries a try and should you have anymore problems/concerns please do not hesitate to contact me again. Thanks, Parth P.
I couldn't see where my table aliases were wrong; however, I went ahead and copy/pasted your re-writes of them, and still got syntax errors. I tried to simplify the query and now it doesn't even run. Well, it ran once successfully, but never again. Now the rs.open statement keeps getting:
Input files:
MasterFile.xlsm, Raw Data worksheet:
Hostname
IP Address
OS Type
Vendor
Name
hostname2
xyz
Server
myvendor2
yyy
hostname1
xyz
Server
myvendor
xxx
hostname2
xyz
Server
myvendor2
yyy
hostname1
xyz
Server
myvendor
xxx
hostname3
xyz
Server
myvendor3
zzz
hostname1
xyz
Server
myvendor
xxx
hostname3
xyz
Server
myvendor3
zzz
hostname1
xyz
Server
myvendor
www
hostname4
xyz
Server
myvendor
xxx
hostname3
xyz
Server
myvendor3
zzz
PowerBi2.xlsx, Sheet1 worksheet:
Owner
Hostname
IP Address
Asset Type
Vendor
Family
Name
Smith, John
Hostname1
xyz
Server
myvendor1
xxx
Smith, John
Hostname2
xyz
Server
myvendor2
yyy
Smith, John
Hostname1
xyz
Server
myvendor1
xxx
Smith, John
Hostname3
xyz
Client
myvendor3
zzz
Smith, John
Hostname4
xyz
Server
myvendor4
www
Smith, John
Hostname1
xyz
Server
myvendor1
yyy
Smith, John
Hostname1
xyz
Server
myvendor1
yyy
Smith, John
Hostname1
xyz
Server
myvendor1
yyy
Smith, John
Hostname3
xyz
Client
myvendor3
zzz
Smith, John
Hostname2
xyz
Server
myvendor2
yyy
Here is the SQL formatted:
Here is the full program:
Sub Report1a()
Dim Sql As String
Sql = "SELECT m.hostname, m.[IP Address], m.[OS Type], m.vendor, m.name " & _
" FROM [Raw Data$] AS m in 'C:\Users\U37T19\Documents\VarunArora\VbaSql\MasterFile.xlsm' 'Excel 12.0 Xml;HDR=YES'"
'Run the query with the SQL string
ExecuteSql1 Sql
End Sub
Sub ExecuteSql1(Sql As String)
Dim filePath As String
Dim master As String
Dim cn As ADODB.connection
Dim rs As ADODB.Recordset
Dim ws As Worksheet
Dim i As Integer
Dim RowCount As Long, ColCount As Long
master = "MasterFile.xlsm"
Workbooks(master).Worksheets("Raw Data").Activate
'Exit the procedure if no query was passed in
If Sql = "" Then
MsgBox _
Prompt:="You didn't enter a query", _
Buttons:=vbCritical, _
Title:="Query string missing"
Exit Sub
End If
'Check that the Menu workbook exists in the same folder as this workbook
filePath = ActiveWorkbook.Path & "\" & master
If Dir(filePath) = "" Then
MsgBox _
Prompt:="Could not find " & master, _
Title:="File not found"
Exit Sub
End If
Set cn = New ADODB.connection
cn.ConnectionString = _
"Provider=Microsoft.ACE.OLEDB.12.0;" & _
"Data Source=" & filePath & ";" & _
"Extended Properties='Excel 12.0 Xml;HDR=YES';"
'Try to open the connection, exit the subroutine if this fails
On Error GoTo EndPoint
cn.Open
'If anything fails after this point, close the connection before exiting
On Error GoTo CloseConnection
'Create and populate the recordset using the SQLQuery
Set rs = New ADODB.Recordset
rs.ActiveConnection = cn
rs.CursorType = adOpenStatic
rs.Source = Sql 'Use the query string that we passed into the procedure
'Try to open the recordset to return the results of the query
rs.Open
'If anything fails after this point, close the recordset and connection before exiting
On Error GoTo CloseRecordset
' make it so this program works on the Movies.xlsx file and not personal.xlsb
Set ws = ActiveWorkbook.ActiveSheet
'Get count of rows returned by the query
RowCount = rs.RecordCount
'Exit the procedure if no rows returned
If RowCount = 0 Then
MsgBox _
Prompt:="The query returned no results", _
Buttons:=vbExclamation, _
Title:="No Results"
Exit Sub
End If
'Get the count of columns returned by the query
ColCount = rs.Fields.Count
'Create a new worksheet
Set ws = ActiveWorkbook.Worksheets.Add
'Select the worksheet to avoid the formatting bug with CopyFromRecordset
ActiveWorkbook.Activate
ws.Select
'Format the header row of the worksheet
With ws.Range("A1").Resize(1, ColCount)
'.Interior.Color = rgbCornflowerBlue
'.Font.Color = rgbWhite
.Font.Bold = True
End With
'Copy values from the recordset into the worksheet
ws.Range("A2").CopyFromRecordset rs
'Write column names into row 1 of the worksheet
For i = 0 To ColCount - 1
With rs.Fields(i)
ws.Range("A1").Offset(0, i).Value = .Name
'Apply a custom date format to date columns
If .Type = adDate Then
ws.Range("A1").Offset(1, i).Resize(RowCount, 1).NumberFormat = "yyyy-mm-dd"
End If
End With
Next i
'Change the column widths on the worksheet
ws.Range("A1").CurrentRegion.EntireColumn.AutoFit
'Close the recordset and connection
'This will happen anyway when the local variables go out of scope at the end of the subroutine
rs.Close
cn.Close
'Free resources used by the recordset and connection
Set rs = Nothing
Set cn = Nothing
'Exit here to make sure that the error handling code does not run
Exit Sub
'ERROR HANDLERS
CloseRecordset:
'If the recordset is opened successfully but a runtime error occurs later we end up here
rs.Close
cn.Close
Set rs = Nothing
Set cn = Nothing
Debug.Print Sql
MsgBox _
Prompt:="An error occurred after the recordset was opened." & vbNewLine _
& vbNewLine & "Error number: " & Err.Number _
& vbNewLine & "Error description: " & Err.Description, _
Title:="Error After Recordset Open"
Exit Sub
CloseConnection:
'If the connection is opened successfully but a runtime error occurs later we end up here
cn.Close
Set cn = Nothing
Debug.Print Sql
MsgBox _
Prompt:="An error occurred after the connection was established." & vbNewLine _
Title:="Error After Connection Open"
Exit Sub
'If the connection failed to open we end up here
EndPoint:
MsgBox _
Prompt:="The connection failed to open." & vbNewLine _
Title:="Connection Error"
End Sub
Input files:
Hostname
IP Address
OS Type
Vendor
Name
hostname2
xyz
Server
myvendor2
yyy
hostname1
xyz
Server
myvendor
xxx
hostname2
xyz
Server
myvendor2
yyy
hostname1
xyz
Server
myvendor
xxx
hostname3
xyz
Server
myvendor3
zzz
hostname1
xyz
Server
myvendor
xxx
hostname3
xyz
Server
myvendor3
zzz
hostname1
xyz
Server
myvendor
www
hostname4
xyz
Server
myvendor
xxx
hostname3
xyz
Server
myvendor3
zzz
Owner
Hostname
IP Address
Asset Type
Vendor
Family
Name
Smith, John
Hostname1
xyz
Server
myvendor1
xxx
Smith, John
Hostname2
xyz
Server
myvendor2
yyy
Smith, John
Hostname1
xyz
Server
myvendor1
xxx
Smith, John
Hostname3
xyz
Client
myvendor3
zzz
Smith, John
Hostname4
xyz
Server
myvendor4
www
Smith, John
Hostname1
xyz
Server
myvendor1
yyy
Smith, John
Hostname1
xyz
Server
myvendor1
yyy
Smith, John
Hostname1
xyz
Server
myvendor1
yyy
Smith, John
Hostname3
xyz
Client
myvendor3
zzz
Smith, John
Hostname2
xyz
Server
myvendor2
yyy
Sub Report1a()
Dim Sql As String
ExecuteSql1 Sql
End Sub
Dim ws As Worksheet
Dim i As Integer
If Sql = "" Then
MsgBox _
Exit Sub
End If
MsgBox _
Exit Sub
End If
cn.Open
rs.Open
MsgBox _
Title:="No Results"
Exit Sub
End If
ws.Select
.Font.Bold = True
End With
With rs.Fields(i)
End If
End With
Next i
rs.Close
cn.Close
Set rs = Nothing
Set cn = Nothing
Exit Sub
'ERROR HANDLERS
CloseRecordset:
rs.Close
cn.Close
Set rs = Nothing
Set cn = Nothing
Debug.Print Sql
MsgBox _
Exit Sub
CloseConnection:
cn.Close
Set cn = Nothing
Debug.Print Sql
MsgBox _
Exit Sub
EndPoint:
MsgBox _
End Sub
Ndndjdhdnjdjdjdjjd
It seems the concatenation is the problem. I've tried using +, &, and ||, but all fail. I need to concatenate columns m.hostname and m.name.
Last updated April 29, 2024 Views 29 Applies to:
