I have done a lot of research on this topic but have found nothing that works. Excel is running extremely slow especially when scrolling and performing basic actions. I don't understand why it's running so slow since I have a pretty decent build.
Other note: This particular file is very low on formulas. (i.e. lookup-type and CPU intensive formulas are not a problem here)
PC Specs:
OS: Win 11 Pro
Processor: AMD Ryzen 7 5700X 8-Core Processor
RAM: 32.0 GB
GPU: Nvidia GEFORCE RTX 3070Ti
Trouble shooting attempts:
Installed any system updates
Turned off automatic calculations
Disabled/enabled GPU hardware acceleration
Updated GPU driver
Started Excel in safe mode
Disabled all add-ins/add-ons
Removed all printers
Restarted PC in a "clean" state (performed a "clean boot")
Not sure what else I can try, but everything I've listed above has not worked.
Thanks for your help!
