My name is Charles Kenyon and I am an Independent Advisor in this forum . This forum is a user-to-user support forum. I am a fellow user with decades of experience using Microsoft Word. I have written extensively on using Word and have help articles on the Microsoft site.
This can be done, and I do it myself. However, it is not simple.
First, you need to be familiar with the ideas of global templates and workgroup templates. Here are links to parts of my article on templates dealing with those subjects.
http://www.addbalance.com/usersguide/templates....
You would want to store the macros and QAT modifications in global templates that you can share between the computers. My recommendation would be to put the templates in OneDrive folders which are mirrored/synced locally.
Ribbon modifications can also be in a Global template, but not the ones you do through the user interface. These require XML modification. This is much more powerful and flexible than those through the user interface but requires more work. See
http://gregmaxey.com/word_tip_pages/customize_r....
In my opinion, it is important that all of these templates be stored locally. Otherwise you will lose the ability to use them if you are off line.
I hope this information helps.
I like to also provide this link about Ransomware even though it has nothing to do with your question:
https://answers.microsoft.com/en-us/protect/for...
Please let me know if you have any more questions or require further help.
You can ask for more help by replying to this post (Reply button below).
Stay well
