· Employment |
[ 2007-Present ] Fedex Express Indianapolis, IN [ 1996- 2000 ] Material Handler · Drive forklift & tug, Sort/ Scan/ Load/ Unload freight & doc mail into trucks & aircraft, Audit, Damage, & Mis-flows. · Safety Team/ Line Leader · Trained new-hires for newly opened area in the hub. · 2x area Employee of the Month/ Attendance Bonuses.
[ 2000-2003 ] Prime Distribution Services Indianapolis, IN Forklift Operator · Pick/ check orders
April 9, 2024
Click here to learn more 💡
May 10, 2024
Word Forum Top Contributors:
How do you move or realign a bullet point and text?
If you'd applied bullets using the Bullets button, you would have a hanging indent automatically. Since you seem to have created the bullets manually, you'll have to create the hanging indent manually.
- Select the paragraphs in question, right-click, and choose Paragraph... In the Paragraph dialog, by Special, choose Hanging. The default half inch will probably be more than you want; 0.25" usually suffices.
- Alternatively, select the paragraphs and drag the Hanging Indent marker on the horizontal ruler (see http://word.mvps.org/faqs/formatting/UsingRulers.htm).
Fairhope, Alabama USA
http://ssbarnhill.com
http://wordfaqs.ssbarnhill.com
Screen shots captured with TechSmith's Snagit
·Was this reply helpful?
See http://wordfaqs.mvps.org/NumberAlignment2007.htm (Word 2007-2010) or http://wordfaqs.mvps.org/NumberAlignment.htm (Word 97-2003).
Microsoft 365 Word MVP since 2005
Volunteer Moderator (Office)
MS 365, Win 11 Pro
Please note that I do not work for Microsoft
MVP program info: https://mvp.microsoft.com/
Last updated January 25, 2024 Views 36,555 Applies to:
