April 9, 2024
Click here to learn more 💡
May 10, 2024
Word Forum Top Contributors:
how can I customize right-click menu in MS Word 2010
If the actions you want to add to the menu are just built-in ones, then you don't have to write macros to carry out those actions -- you can put in items using the built-in ID numbers as Greg does for "Bookmark" and "New Comment". But you will need at least the one macro (in Greg's example, Sub BuildControls) to insert those items into the right-click menu.
There's another complication that Greg's page mentions but doesn't cover in any detail: Word has lots of different right-click menus. The one he uses, the "Text" menu, is the one you get when you right-click plain ordinary text. But there are other ones for when you right-click a table, or a picture, or any one of a dozen or more other things that might be in a document.
If you're 'scared' of programming (sorry, not something that I've ever experienced), it might be best to describe in detail what you want to do, and get someone else to write the macro for you -- and maybe explain how it works so you can tweak it if necessary.
https://jay-freedman.info
http://word.tips.net/T000986_Deleting_a_Macro.html
You won't damage settings by adding or removing macros. At worst you will temporarily override a command if you name your macro with the underlying command name.
Here are some links that should help with the Icon IDs
http://www.istartedsomething.com/20060916/756-icons-office-2007/ - this page has a graphic with 756 icons extracted from Office 2007. Includes link to instructions on how to do extract
RibbonX Updates for B2TR
https://blogs.msdn.com/b/jensenh/archive/2006/09/15/755336.aspx?Redirected=true – How to extract MSO ID’s and download 2007 Icons Gallery.
Images are in the ImageMso 0 and ImageMso 1 commands at the bottom of the File Tab menu.
Source: https://www.microsoft.com/download/en/details.aspx?id=21103
Also take a look at this link:
http://soltechs.net/CustomUI/imageMso01.asp
2007 Office System Icons Gallery spreadsheet - https://www.microsoft.com/download/en/details.aspx?DisplayLang=en&id=11675
As computer scientists we are trained to communicate with the dumbest things in the world – computers –
so you’d think we’d be able to communicate quite well with people.
Prof. Doug Fisher
Last updated February 16, 2024 Views 12,146 Applies to:
