Has anyone come across this. All new spreadsheets unusable
April 9, 2024
Click here to learn more 💡
May 10, 2024
30 people found this reply helpful
·Was this reply helpful?
Hi
Jen is new to the forum and Excel. Following the link Jen provided will not solve this for you.
The problem you are having is caused when you upgrade Mac OS to Catalina or Big Sur but failing to install the free update that is required. The fix is easy and simple:
Download a copy of the current version of AutoUpdate from this link, install and then run AutoUpdate to bring your installation to current update level, then restart your Mac. If the updater does not open automatically after download, double-click the downloaded .pkg file. Click this link to download the updater. The update is free.
55 people found this reply helpful
@ Jen
Hi
Welcome to Excel for Mac forum.
This is a well-known issue with a simple solution, as per my post.
Simply installing updates will fix it, but a new version of AutoUpdate app must be downloaded and installed. If a user goes to the Help menu and chooses Check for Updates, they will be told no updates are available, so you can't give advice to do that.
Whenever you see someone post that the Excel interface is upside down, you know it is because they upgraded Mac OS and did not install the new version of AutoUpdate. Keep this in your toolbox, because it happens a lot.
