I cannot get this formula, been at it for hours. any help would be appreciated.
EXCEL-4. Add formulas to complete the table of hours used. In cell B17, create a nested formula with the IF and SUM functions that check if the total number of hours worked in week 1 (cells B9:F9) is equal to 0. If it is, the cell should display nothing (indicated with two quote marks: ""). Otherwise, the cell should display the total number of hours worked in week 1. Copy the formula from cell B17 to fill the range B18:B20.
