Hi, I set default numbering for captions. However when the caption dialog box displays, the figure value does not display as default in the caption box. I cannot write in it to append the title of the caption. How do I fix this?
If the Caption style has a (large) left indent or is defined to have center alignment, the preview may not be correct in the dialog box. This is an old bug in Word. If you click OK to insert the caption, does it display properly in the document?
Stefan Blom MS 365 Word MVP since 2005 Volunteer Moderator MS 365, Win 11 Pro ~~~ Note that I do not work for Microsoft https://mvp.microsoft.com/ ~~~ Please specify Word version & OS in your question
Last updated February 4, 2025
Views 243
Applies to:
