Bullets or numbers do not move to the right or left by using the TAB key or Shift TAB key.
I have to Open the Bullets then select "Change the List Level," and then select the level; this sucks!
This has to have a simple fix.
Can you help me get the TAB key to work so I can use it to "Change the List Level"   SWEET!!!!!!!!!!!!
Click File tab | Options | Proofing | AutoCorrect Options. On the AutoFormat As You Type tab, make sure that "Set left and first indent with tabs and backspaces" is selected. Click OK twice.
Stefan Blom
MS 365 Word MVP since 2005
Volunteer Moderator
MS 365, Win 11 Pro
Note that I do not work for Microsoft
https://mvp.microsoft.com/
Please specify Word version & OS in your question
28 people found this reply helpful
Last updated October 24, 2024 Views 9,945 Applies to:
