APA bibliography not sorted alphabetically for Word for Mac (version 15.32)
Hi Eunice,
Please follow the steps below to see if this can help you solve the problem:
Select the bibliography contents>Click the drop down button on the left of “update Citations and Bibliography”>convert bibliography to static text
Select the bibliography contents>use the AZ sort feature to sort them.
Rena
[Updated by Rena Yu MSFT, 02:48 May 4, 2017(UTC)]
33 people found this reply helpful
·Was this reply helpful?
Hi Eunice_Ong,
Based on our test, APA sorted fine on our side. To move forward, we’d like to confirm some information to better help you.
1. Try reinserting citations on your Mac to see whether they will be sorted by alphabetically sorted.
2. Does this problem happen to only one file or all the documents?
Tisky
20 people found this reply helpful
Hi Eunice_Ong,
I would like to explain that we can sorted APA, however it is not feasible to sorted the bibliography.
We suggest you vote for your requirement to Word UserVoice, which will help better our products and services.
Thanks for your understanding.
Qing
Last updated April 14, 2025 Views 43,025 Applies to:
