June 10, 2024
PowerPoint Forum Top Contributors:
Align equations at the equal sign in power point 2013.
Check this.
I have found one solution:
(1) write the equation in Word 2013.
(2) align with "=".
(3) copy the equation to PowerPoint 2013.
Anyone has any other solution?
Thank you!
Junfei Tang
·Was this reply helpful?
Thank you Junfei Tang for trying to find a solution to my question.
I tried what you suggested and it works if I paste like a picture. However, I would like to use animation to show each step. If I paste like a picture I wouldn't be able to animate each step of the solution to the equation.
Hi Giselle Martinez,
I think what I have experienced is different from you. After I pasted the equation from Word 2013 to PowerPoint 2013, I can still edit it as an equation. For example, I can still change the color of it:
As you can see, the "Equation Tools" is activated and it operates normally as usual.
When you paste, you can use "Ctrl + V".
Or, you can right click, and choose the first option "Use Destination Theme" under the "Paste Options":
Do not choose the third option "Picture".
Sincerely,
Junfei Tang
I see your problem. The reason is that you copy and paste the "equation" instead of the entire "text box".
Please try this:
(1) write the equation in PowerPoint 2013.
(2) copy and paste the entire "text box" into Word 2013.
(3) align the equation in Word 2013 at "=".
(4) copy and paste the entire "text box" back into PowerPoint 2013.
Sincerely,
Junfei Tang
Just use the equation array object:
\eqarray(1+2&=3@3&=1+2)
where &= aligns at "="
35 people found this reply helpful
Last updated June 2, 2024 Views 17,355 Applies to:
