Hi Mohammed
I'm AnnaThomas and I'd be happy to help you with your question. In this Forum, we are Microsoft consumers just like yourself.
Sorry for the trouble this might have caused. Here are a few things you can check to troubleshoot the issue:
Verify that the synchronization service is running. You can check this by opening the Synchronization Service Manager on the server where the AD Connect agent is installed. If the service is not running, start it and monitor for any error messages.
Check the event logs on the server where the AD Connect agent is installed for any errors related to synchronization.
Verify that the account used by AD Connect has the appropriate permissions to read and write to Active Directory. You can do this by opening Active Directory Users and Computers, selecting the domain, and going to Properties > Security > Advanced. Check that the account is listed and has the appropriate permissions.
Verify that the account used by AD Connect has the appropriate permissions to access Azure AD. This can be done in the Azure portal by going to Azure Active Directory > Users > User Settings > Device settings, and checking that the account has the required permissions.
Check the synchronization rules in AD Connect to ensure that they are set up correctly and are not causing any conflicts.
If none of the above steps resolve the issue, try resetting the AD Connect sync engine. You can do this by opening the Synchronization Service Manager, selecting the Connectors tab, and then right-clicking on the Active Directory connector and selecting "Reset Sync".
I hope this helps ;-), let me know if this is contrary to what you need, I would still be helpful to answer more of your questions.
Best Regards,
AnnaThomas
Give back to the community. Help the next person with this problem by indicating whether this answer solved your problem. Click Yes or No at the bottom.
