A problem font - how to remove when saving Powerpoint?
How to fix? "Noto Sans Symbols Font not available" every time we save the fix? Any ideas? Thanks, Chris
Hi Const Koala,
May I know if you received PowerPoint presentation from someone?
A common problem is lack of fonts that you used on the original computer, that are not present automatically on other computers. This error usually appears if the original PowerPoint presentation is opened in another computer and has the text in a font that is not present in other computers.  If this is the case, there are view measures that can be taken to prevent the error:
  1. Use common fonts- Use common fonts only like Arial, Segoe, Times New Roman, Courier etc. that are supplied with Office apps. This way you do not need to install the third-party fonts on all the machines.
  2. Embed the fonts in your presentations- PowerPoint has the option to embed fonts in your presentation. Reference: Benefits of embedding custom fonts (microsoft.com)
If someone has shared the PPT with you, you can suggest the user to either create the PPT with the built-in fonts or embed the custom font with the PPT so you can install it on your computer.
If the above mentioned is not your scenario, please provide us with the following information for our understanding:
  1. Please provide the screenshot of Microsoft 365 Product Information. To get this screenshot, open PowerPoint on your system, click File>Account, capture the screenshot of all the information mentioned under Product Information.
  1. A screenshot of the error.
  2. May I know if received the affected PPT from someone else?
  3. Do you get the same error in PPT that you have created on your computer?
Neha
•Beware of Scammers posting fake Support Numbers here.
•Please let us know if this is helpful and if the solution worked for you, as it can benefit others who are facing the same scenario.
Last updated April 14, 2025 Views 6,843 Applies to:
