This issue popped up for me AGAIN after updating my XPS 7590 to Windows 11. Prior to upgrade to Windows 11 Modern Standby was working fine. Since Windows 11 update fans randomly spool up during sleep.
Initial troubleshooting: Updated to the
*Latest drivers from Dell
*Latest Windows update
*Latest BIOS
Tried forcing S3 sleep with the following command in the CMD prompt: reg add HKLM\System\CurrentControlSet\Control\Power /v PlatformAoAcOverride /t REG_DWORD /d 0
This fixes the overheating/fand in sleep BUT kills Bluetooth in S3 sleep.
Current workaround:
1. Enabled hibernated in command prompt: powercfg.exe /hibernate on
2. Switched from Sleep to Hibernate in the Control Panel->Power Options under all scenarios when sleep would normally be initiated: closing lid, pressing power button
3. Set Sleep to "Never" in the New Windows Settings app (both plugged in and on and battery)
4. Set to Hibernate when on battery power after 15 minutes in Control Panel->Power Options->Advanced Power Setting (Always on when plugged in).
So far this seems to be working. Suboptimal but OK
