Folks, this is serious, can someone please help me??
I have Windows 10 Pro 32 bit Insider Preview Build 14901 running now on a 64 bit capable computer (Intel I5 quad core) simply because I have neither the time or money to upgrade all my old programs. Last week I found it had not been updating. I tried to update manually. It downloaded fine, went through the preparation process fine but stopped as soon as it began to run the update throwing error code 0x8007000e. I researched this error code a little and found it could mean any number of things but most likely missing or corrupted files so I dropped into CMD with administrative privileges and ran sfc /scannow. It completed and reported no problems. I rebooted and tried the update again. Once again error code 0x8007000e I ran the update troubleshooter and it reported it found and fixed four problems:
I rebooted and tried again. Error code 0x8007000e
Just for chuckles, I tried running the trouble shooter again and got exactly the same result. Apparently the fix didn't take so I finally remembered that about a year ago right after I had Windows 10 up and running, I cloned my C: drive onto an extra hard drive so I dropped into elevated CMD again and ran DISM with the /restorehealth argument using my system clone F: as source. It reported it had finished successfully. I rebooted and tried again. Error code 0x8007000e
I looked at my restore possibilities but found that my oldest restore point wouldn't get me back prior to the 14901 update.
I tried resetting the system, of course losing all my programs and most of my settings in the process. I'm not complaining about that. I've been down this road many times before but that surely should have fix the problem, right? Wrong! Error code 0x8007000e.
I again ran the troubleshooter and it again reported the same four problems found and fixed.
I removed all third party software, disconnected everything except the mouse and the keyboard, deleted everything in the update download folder and did a clean boot. Tried running the update again. Error code 0x8007000e
Again ran the update troubleshooter and it reported it had found and fixed the same four problems as before.
I have to tell ya' folks, I've been a loyal Microsoft fan since DOS 3.1 but at this point it's probably a very good thing that Redmond, WA is so far from Lancaster, OH. Otherwise I might drive on over and have a monumental hissy fit and nervous breakdown right in your front lobby. I might even cuss. To top everything off my issue of the insider preview 14901 has taken to reminding every time I reboot that on the first of the month my system will turn into a pumpkin and my mouse will turn white.
If anyone there can please give me an answer on how I should proceed I would be very grateful.
Thank you very much!
