These Backward Compatibility Essentials for W10 Could Make or Break It?
As a machinomic writer, I depend on certain key programs with my copy of Windows in order to produce the maximum output.  While the offer for a free upgrade to Windows 10 sounds promising, there are a few concerns I have that could keep me from going forward with the upgrade right away:
1. Adobe CS2.  This is a big one.  I don't know what the future holds, and would prefer not to get locked into a version of Adobe that would require a monthly subscription to access features via the Creative Cloud  I like my standalone; but my standalone is the way-outdated CS2.  Would I be able to run Photoshop CS2 on Windows 10 if I put the program in compatibility mode?  I would prefer not to have to buy a more modern version of Photoshop or Illustrator if I can help it, as even CS5 can be pricey still.  If it comes down to the worst, I could always download Gimp; but I fear Gimp would have to update significantly to accommodate W10.
2.  Office 2007.  Yes, it's 8 years old (at time of post.)  Yes, I know I should probably upgrade.  But again, I don't usually have a spare $500 lying around for a full office upgrade.  And I would want to know that I can run Word, Excel, Access, PowerPoint, and especially Publisher 2007.
3.  The Sims 3.  It barely runs with most stuff packs and all expansion packs on Windows 7.  Would 10 make the game's operations better or worse?  I run an HP Pavilion p6540y with 8GB of RAM.  The reason I still use it in spite its horrible inefficiency is because of the control over character puppetry and control over lighting it allows for screenshots, something I have neither of in significant amounts in Sims 4.  I have all but completely retired Sims 2 for these purposes, as that game is ancient history now.  Just in case, I'm also curious how compatible Sims 2 and 4 would likely be with 10.  I know EA will update Sims 4 periodically to improve it.  I don't have that same assurance for 2 and 3, given the age on those games.
Another reason that this is a big one is because it will be a while before I can upgrade to a Surface Pro 3 (or 4 in the future?)  So I have to make my HP Pavilion work for at least another two years, even though it's beginning to slow down with age after being in service for five years solid.  And I can't do my webcomic storytelling too easily on a Kindle Fire, which is my current laptop-ish device since my Dell gave up the ghost.
And speaking of the Kindle...
4.  Kindle Fire software.  How well would I be able to operate software on Windows 10 that interfaces Windows with my Kindle?  I'd like to be able to manage files on both PC and Kindle, something which I find clumsy to do with Windows 7.  I realize that the Windows and Android platforms are two very different birds; but the sync with Microsoft and Amazon would be a similar compatibility concern for me as with Microsoft and EA.
5.  iTunes.  It has taken quite a while to get a recent version of iTunes to work properly on my Windows 7.  I'd like to know that if I have any problems running iTunes after an upgrade to 10, that it would be on Apple's end and not Microsoft's.  If so, I'll simply wait for Apple to update things on their end.
I realize that this post can only give me insight on the Microsoft end of things, and I'd have to contact those other companies as well.  But any assistance in understanding these topics would be greatly appreciated.
Hi Ivan,
The Windows 10 Technical Preview is an operating system which is still in the beta phase. So there is a chance that some applications won't work as expected. Some of the applications you have mentioned are really a bit old, so there might be a possibility of it not going well with Windows 10 Technical Preview.
If the applications are compatible with Windows 8.1 operating system which is a stable operating system from us then there is a very high chance that it will work with Windows 10 Technical Preview. Please check the links mentioned below to find out the compatibility status of the applications with Windows 8.1 .
Adobe Photoshop CS2
Microsoft Office 2007 Professional Plus
The Sims 3
Amazon Kindle Fire 7" Tablet
iTunes
You may also check the link mentioned below to run the applications in Windows 8.1 Compatibility mode.
Make older programs compatible with this version of Windows
However, please keep on checking regularly from the application manufacturer end to see whether they have released any new updates if they have then install it and then check it.
I would like to repeat that since Windows 10 Technical Preview is in the infancy so some applications may find it a bit difficult to work on.
Please revert if you face any issues with Windows 10 Technical Preview.
Two things that may be of interest:
1) You can create a dual boot PC with both Windows 7 and the Windows 10 Previews installed (and upgraded to a new build periodically) for test compatibility.
How to Dual Boot: http://www.pagestart.com/win7win10tpdb10121401.html
2) You can speed up Windows 7 by moving from a hard drive to a Solid State Drive.
http://www.pagestart.com/win7sddatihim05011201.html
J W Stuart: http://www.pagestart.com
Never be afraid to ask. This forum has some of the best people in the world available to help.
Solid state drives have a far more finite life span than conventional platter based hard drives, when used for read/write operations. For this reason, I personally would only recommend Solid State Drives for use only in read-only situations.
I do not recommend using Solid State Drives as primary OS drives, or in any situation where said drive would be read from, and written to on a consistent basis. This is the same for all FLASH based drives.
Jay
Sorry to disappoint you but I've been using a SSD as my primary Windows 7 drive for more than 2 years and the "TWARE" S.M.A.R.T. value has not degraded.
You're not disappointing me in any way. Different factors can decide how long a flash-based SSD can last, how fast it is, and how reliable it is.
Some factors include:
  • Enterprise Grade SSDs last longer, and are more reliable than consumer grade SSDs
  • Single-Level Cell SSDs are generally quite a bit faster, and more reliable than Multi-Level Cell SSDs
  • SSDs that use wear-leveling technology will degrade at a slower pace than those without, but they will still degrade, and ultimately fail
  • Power outages can potentially cause catastrophic, and unrecoverable data loss across the entire drive (Compared to only a few blocks, if any at all, on standard platter based drives)
  • Drive Manufacturer is one of the biggest factors in all fields, when it comes to SSDs.
"Each block of a flash-based SSD can only be erased (and therefore written) a limited number of times before it fails." - Wikipedia concerning reliability of flash-based SSDs.
Disclaimer: The above information in this post applies only to Solid State Drives that use flash-based memory. DRAM SSDs do not suffer from finite write life cycle. Hybrid SSDs that rely on flash-based memory will take longer to degrade than one that is flash-based only.
Jay
I am with you Ivan. I have an entire Adobe Publishing collection. I realize that some of the programs included will not work on a 64 bit OS, but some do. I have Illustrator 9 and Photoshop 6.0 running on 5 Win 7 computers right now, 3 of which are x64. That represents a large investment, and a replacement cost that I should not have to incur. Yes Win 10TP is not a done deal, so hopefully they will get the compatibility issues sorted out, but this would be a deal breaker for me. Heck I can run these programs on Linux for goodness sake, so not being able to run them on a Windows version is just not acceptable. I like Win 10 so far (though the simplistic blocky metro look is seriously disappointing) and I would seriously consider upgrading from 7 to 10, but not if this issue isn't fixed. So fingers crossed that they listen to us and get things sorted out. My big fear is the, oh that's too old, go buy new stuff, attitude will prevail, and ruin Win 10 for a number of us.
Early SSD's had short lifespans but modern SSD's are at least as reliable as mechanical/platter HDD's, but I would use an SSD with power loss protection.
An SSD even without PLP is far more reliable than a hard disk drive. Just ask anyone with a laptop that has a hard drive and accidentally dropped it and another user who has an SSD in their laptop and dropped it.
This assumes that no other part of the laptop such as the display was not damaged when it dropped.
i stand corrected. guess I'm a little behind on SSD drives.
Jay
Some interesting food for thought.
If a user where to install Windows 10 (the Retail version when its released) on an SSD, remove the SSD and also install 10 on a Hard Drive and then remove it.
Now let both drives set on the shelf for say 5 years and then connect the SSD and see if it boots to Windows and try the same for the hard drive, which drive technology (SSD or HDD) would still allow Windows 10 to load and operate properly?
Last updated February 2, 2021 Views 1,017 Applies to:
