Thank you for keeping us updated on the status of the issue.
As per the information, it seems that third party applications or pending updates are causing the issue.
Let’s make it simpler for you.
Follow the manual steps, which will help you how to boot the computer in clean boot state and then we will eliminate software conflicts.
Step 1:
a) Press the ‘Windows + R’ key on the keyboard.
b) In the ‘Run’ window, type ’MSCONFIG’ and click ‘Ok’.
c) On the ‘General’ tab, click to select the option ‘Selective startup’, and then click to clear the option Load startup items
check box.
d) On the ‘Services’ tab, click to select the ‘Hide all Microsoft services’
check box, and then click ‘Disable all’.
e) Click ‘OK’, and then click Restart.
Note: If your computer don't go in restart loop, then follow the next steps.
f) Repeat the above steps a & b, and on the ‘Startup’ tab, click ‘Open Task Manager’. In the Task Manager window under startup tab,
right click on each startup item which are enabled and select ‘Disable’.
Step 2:
Enable half of the services.
a. Follow steps 1a and 1b to start the System Configuration utility.
b. Click the Services tab, and then click to select the
Hide all Microsoft servicescheck box.
c. Click to select half of the check boxes in the
Service list.
d. Click OK, and then click Restart.
Step 3:
Determine whether the problem returns.
If the problem still occurs, repeat step 1 and step 2. In step 2, click to clear half of the check boxes that you originally selected in the Service list.
If the problem does not occur, repeat step 1 and step 2. In step 2, select only half of the remaining check boxes that are cleared in the Service list. Repeat these steps until you have selected all the check boxes.
If only one service is selected in the Service list, and you still experience the problem, the selected service causes the problem. Go to step 6. If no service causes this problem, go to step 4.
Step 4:
Enable half of the Startup items.
If no startup item causes this problem, a Microsoft service most likely causes the problem. To determine which Microsoft service may be causing the problem, repeat step 1 and step 2 without selecting the
Hide all Microsoft services check box in either step.
Step 5:
If the problem still occurs, repeat step 1 and step 4. In step 4, click to clear half of the check boxes that you originally selected in the Startup Item list.
If the problem does not occur, repeat step 1 and step 4. In step 4, select only half of the remaining check boxes that are cleared in the Startup Item list. Repeat these steps until you have selected all the check boxes.
If only one startup item is selected in the Startup Item list, and you still experience the problem, the startup item that is selected in the list is the service that is causing the problem. Go to step 6.
Step 6:
Resolve the problem
After you determine the startup item or the service that causes the problem, contact the program manufacturer to determine whether the problem can be resolved. Or, run the System Configuration utility, and then click to clear the check box for the
problem item.
Step 7:
Important Note:After you have finished troubleshooting, follow these steps to boot to normal startup.
b) In the ‘Run’ windows type ’MSCONFIG’ and click ‘Ok’.
c) On the ‘General’ tab, click the ‘Normal Startup’ option, and then click ‘OK’.
d) When you are prompted to restart the computer, click ‘Restart’.
Hope the information helps.
Please reply with the results, in order to help you fix the issue.
Thank you
