Split from this thread.
22572.100 ni_release one issue so far
Won't let me move my system tray icons where I want anymore.
Other than that, installed fine on both laptops.
0 people found this helpful
Was this discussion helpful?
I opened Sys Tray to try this and I cannot repro it. Sometimes nothing more than a reboot will do the trick for things. Did you try Restart Exporer.exe?
Cheers,
Drew
Cheers,
Drew
Sys Tray is where the Time/Date, Sound etc. are. You
don't open the Sys Tray.
Tried a reboot, and closed explorer / restarted explorer still the same.
Just tried it here as well and is working.
Yes, was a bad word to use. I should have used "show", it shows, FOR ME, on demand; I can have it show or not. As opposed to default where it's visible constantly. Ooops.
Cheers,
Drew
Glad it's working well on your end, but not on mine made a FBH report about it.
I never knew the Sys Tray icons (Time/Date, Volume etc.) could be moved.
Yes, same as task bar icons and browser tabs.
Cheers,
Drew
Hi CK,
I think he was referring to move the icons around in the system tray.
All the icons on the right of the taskbar in settings are now called "Other system tray icons" not just Time/Date and the 3 on the far right that are bundled together and cannot be moved.
(Network,Volume,Battery).
All the other ones can be shuffled around in the tray.
·Was this reply helpful?
Hi CK,
Correct. Unhidden icons can be moved, What I've always called
Sys Tray icons can not.
