I have an Asus Zenbook. After/during the latest Windows 11 update, I am no longer able to boot into windows. I get Stop code: DRIVER PNP WATCHDOG BSOD, and sometimes INACCESSIBLE BOOT DEVICE. I can't get to the recovery environment, although BIOS is still working.
Hi timleeshue,
Check your hard drive with the manufacturer's software as it looks like it's failing, it can also be the controller or the cable to the hard drive, most of the time it's just the hard drive.
·Was this reply helpful?
In the bios is the hard drive still listed correctly and do you know the make and model of the hard drive?
Hi. Thanks for tryingto help. In the BIOS, the storage is still being recognised and listed as NVMe SSD (Intel optane).
I was thinking of trying to boot from a flash drive and performing a factory reset/removing updates
Yes you could try, I would still check the hard drive, do you know the make and model of the hard drive or the model of your computer so I can look it up.
It's an Asus Zenbook UX325E
I think you might be correct on the hard drive issue. I tried to reinstall windows, and it couldn't find a drive to use
I will check tonight NZ time and see what can to done, did you alter any settings in the bios before this problem?
You need to load the driver
No. Nothing. Just the Win11 OS Update
Thanks. That got me a little further, but i ran into the same error 5 minutes after starting the driver installation. Even when i disable VMD, the only drive recognized is the USB drive.
I really do appreciate the help
Last updated April 12, 2025 Views 3,631 Applies to:
