Phone screen – Supported devices
The phone screen feature is now available publicly. With phone screen you can mirror your Android phone’s screen directly on your PC without having to dig for your phone. The official list of supported devices is available here.
Supported PCs
Any PC running Windows 10 October 2018 Update (version 1809) or later.  However, we always recommend updating to the latest available version.
Supported phones
The feature is available on select Android devices that have the Link to Windows integration.  The official list of supported devices is available here.
We will continue to expand the list of devices over time.  
Was this article helpful?
Yes
No
Please support OnePlus devices ;), otherwise I am hoping for the best for this app moving forward.
492 people found this comment helpful
Was this comment helpful?
Yes
No
How satisfied are you with this comment?
Can someone provide a list of Bluetooth USB dongles that are known to support Bluetooth radio supports Low Energy Peripheral Role?
Side note I think you can also use the Bluetooth LE Explorer from the Windows Store and the Virtual Peripheral option to see if the necessary Bluetooth mode is supported. Its results match what I saw in the Device Manager in that Peripheral mode is not supported on my desktop computer with the current Bluetooth dongle I have. Below is the link if anyone wants to try it out.
https://www.microsoft.com/store/productId/9N0ZTKF1QD98
308 people found this comment helpful
Yes
No
Sounds great and as I am currently using a Surface Go and have an S9+ I can't wait to try this out, any idea on when it will become available?
81 people found this comment helpful
Yes
No
Can android app has access to Window devices like Camera, microphone etc ?
102 people found this comment helpful
Yes
No
Not compatible with surface pro 6, i5 4gb ram 128gb storage. So sad for me!!
125 people found this comment helpful
Yes
No
I have a Surface Book 2, and yet I do not see "Radio Driver or Adapter for Bluetooth" under my Bluetooth options.  Can you update this info to cover all of your products, please?
130 people found this comment helpful
Yes
No
Update - Marvell AVASTAR Bluetooth Radio Adapter and...
192 people found this comment helpful
Yes
No
As soon as I saw that it was a Marvell adapter, I knew it wouldn't be supported. :(
Yes
No
Please support at 3.1 class otherwise I am hoping for the best for this app moving forward
9 people found this comment helpful
Yes
No
I am running Win 10 1803. Bluetooth fits requirements + have an s9. How to get the insider build of the your phone app?
101 people found this comment helpful
Yes
No
Forum Article Info
Last updated August 13, 2021 Views 178,955 Applies to:
