Paint 3d how to draw straight lines to draw some objects
To insert a line in Paint 3d, kindly click the line icon on the right part of the Paint window. For reference, please see the photo below.
Feel free to contact us if you need assistance with Windows.
·Was this reply helpful?
Workstation:
Intel I9 9900K 5Ghz
64GB of trident Z RAM
MSI RTX 2060 Super 8GB
Samsung Evo 2TB SSD
Asus Prime z390 board
19 people found this reply helpful
Thanks for the reply. But i don't see line icon on the version i am using. As in the attached image.
The paint 3d version i have is 1.1701.12017.0.
54 people found this reply helpful
As for the screenshot and information provided, we will have this concern investigated by the software developer. We will let you know if there will be further updates.
Let us know if you have other concerns.
Workstation:
Intel I9 9900K 5Ghz
Samsung Evo 2TB SSD
Same for me as well, no line tool...
I've had to make very thin rectangles to work around it but that doesn't seem like the intended method to draw a simple straight line, especially in a program that's the successor to MS Paint.
I have the same paint 3d version. I found in other web page that you can draw a line by holding shift while drawing it and it works.
It would be good to rotate the line that is draw at any time as it is done in Visio.
Hope that helps!
Last updated April 30, 2024 Views 11,819 Applies to:
