.NET Framework 3.5 and 2.0 installation issue
I'm using Windows 10 Pro Version 1903 (OS build 18362.1)-
I'm trying to install .NET framework 3.5 and 2.0 feature, but somethings go wrong and I received the error
Update NetFx3 of package Microsoft .NET Framework 3.0 failed to be turned on. Status: 0x800f0950.
Could someone help me to fix this issue.
Thank you and regards
Giuseppe
Last updated January 31, 2020 Views 2,119 Applies to:
I've solved the issue installing last build of OS from Windows Update.
With all due respect, you cannot solve it by installing a new build. Simply because .Net Framework 3.5 is not enable by default, you have to manually turn it on via "Turn Windows features on or off"
I apologize if I haven't been clear :) I've solved the issue installing the KB4497464. As describe here https://blogs.windows.com/windowsexperience/2019/03/20/announcing-windows-10-insider-preview-build-18362/ "We fixed an issue where users were unable to enable\disable .NET Framework or other optional feature- on-demand (FODs) after installing recent Cumulative Updates."
Regards
Giuseppe
