Multiple Event ID 10005 Errors - Build 14279 64-bit
I'm getting large numbers of Event ID 10005 errors - 597 so far in the last 7 days. In previous Builds I was getting mostly Event ID 7031 and 10016 errors, and still am, but 10005 is now off the charts in numbers by comparison. See examples here.
DCOM got error "1084" attempting to start the service dps with arguments "Unavailable" in order to run the server: {DDCFD26B-FEED-44CD-B71D-79487D2E5E5A}
DCOM got error "1084" attempting to start the service ShellHWDetection with arguments "Unavailable" in order to run the server: {DD522ACC-F821-461A-A407-50B198B896DC}
DCOM got error "1084" attempting to start the service WSearch with arguments "Unavailable" in order to run the server: {7D096C5F-AC08-4F1F-BEB7-5C22C517CE39}
I'm getting multiples of the above three examples with WSearch being the most. Is anyone else seeing large numbers of Event ID 10005 errors?
I don't know.. maybe take a look at this page;
https://technet.microsoft.com/en-us/library/cc774489%28v=ws.10%29.aspx?f=255&MSPPError=-2147217396
Maybe looks like the usual cause is small, missing, or corrupt paging file.
Microsoft Bob came back after a 20 year makeover, and with a new name. Cortana!
Thanks Mike. I just checked my error count with Build 14257 and had reported 270 Event ID 10005 errors over 7 days with the Feedback App. Don't have my 10005 error count for Build 14271, but this appears to be a continuing problem with my Fast Ring Build updates.
This looks like a server connection problem.
They all say "in order to run the server"
Around computers
since 1952
lacrumb
Yes LC and they also say "attempting to start the service". When I check Services, all three listed above are running. The only ISP I've been using with this Build is the local Library wireless - high speed FIOS. None of my Windows 7 PCs show a 10005 error using the same Library Server. Windows 7 has the same three Services. Maybe it's a Server on Microsoft's end related to Windows 10? I also work offline at home some. Maybe it's trying to contact a Microsoft Server repeatedly but can't? It looks like over 90% of the 10005 errors are WSearch.
It could well be om the Microsoft end.  Did you put this into Feedback?
Around computers
since 1952
lacrumb
You might want to try rebuilding the indexing service.
Control Panel / Indexing Options / Advanced... push the Rebuild Button.
It could well be on the Microsoft end.  Did you put this into Feedback?
Yes LC, I posted in the Feedback App. This also may be related to File Explorer crashes being reported below using Search in File Explorer. The WSearch Service provides Content Indexing and Search Results in File Explorer. My File Explorer crashes as noted below.
http://answers.microsoft.com/en-us/insider/forum/insider_wintp-insider_files/file-explorer-crashes-on-search-build-14271/4ea9d7ac-dad4-4dab-8b06-691fead6e958?page=3&msgId=50a5fa2e-fc51-4519-b564-87c36dd9d891
Last updated February 2, 2021 Views 14,457 Applies to:
