Recently I updated my laptop to the latest test build of Windows 11 (22000.100) and I was scrolling through my apps list installing the bloatware that came it only to notice a phantom app at the bottom called "ms-resource:DisplayName". I tried to uninstall it by right clicking and just pressing the uninstall button but nothing happened. Is there like another way to dry and delete it I haven't heard off?
ms-resource:DisplayName, what is it?
Hi
ms-resource:DisplayName is an app used by Windows.
You cannot delete it.
You can refer this:
·Was this reply helpful?
File feedback:
Opinions expressed are solely my own and do not represent the views or opinions of Microsoft.
This also happened in windows 10 when i first installed
it turnrd out to be People app
so try checking for updates in microsoft store
Last updated April 29, 2024 Views 21,693 Applies to:
