Mobile Hotspot connections are stuck at Obtaining IP Address
I am unable to connect any devices to a Windows 10 mobile hotspot.
All of them are not assigned IP addresses through what I assume should be DHCP.
Wondering if anyone can assist me on this
I request you to refer the following article:
http://windows.microsoft.com/en-us/windows-10/use-your-pc-as-a-mobile-hotspot
Hope the information helps to fix the issue, if you have any further queries, feel free to post. We are here to assist you.
This information gives no debugging process on what may solve the issue. Only a five step process on how to enable it, which, given the context in the OP doesn't even sound like this article has any value whatsoever in this case
318 people found this reply helpful
Any idea how to solve this so far?
Right-click on the network icon and select Network and Sharing Center. Then click on Change adapter settings. This shows all your adapters and connections. Right-click on the Ethernet connection and select Properties, then click the Sharing tab.Untick the  Checkbox to Allow sharing the connection and the other one also.Then again try to restart mobile hotspot.
1144 people found this reply helpful
In my case, the internet sharing was incorrectly linked with my Wi-Fi adapter instead of the hotspot adapter. Here's how I fixed it.
  1. Open Mobile hotspot settings (Settings > Network & Internet > Mobile hotspot)
  2. Turn on mobile hotspot
  3. Under "Related Settings", click Change adapter options
  4. Take note of which adapter is connected to the internet and which adapter is your mobile hotspot (typically named "Local Area Connection* [#]")
  5. Right click the adapter that is connected to the internet and click Properties
  6. Go to the Sharing tab
  7. Uncheck "Allow other network users to connect through this computer's Internet connection". If it is already unchecked, skip this step.
  8. Click OK
  9. Again, open PropertiesSharing for the same adapter.
  10. Check "Allow other network users to connect through this computer's Internet connection"
    (If you get a popup that says "Internet Connection Sharing is currently enabled...", click OK.)
  11. Under "Home networking connection:", select the mobile hotspot adapter
  12. Click OK
1032 people found this reply helpful
Follow the steps and your Windows 10 Mobile Hotspot will start to work in no time.
Step 1: Go to  Network and Sharing Centre.
Step 2: Under View your active networks click the network you are getting Internet from.
Step 3: Click on Properties < Sharing
Step 4: Select Allow other network users to connect through this computer's internet connection
Step 5: Click OK
72 people found this reply helpful
Given that your sharing is properly set by your Ethernet or Wi-Fi to your Local Area network you have to restart Internet Connection Sharing service from the "services.msc" window and voila you are done !!
54 people found this reply helpful
Thanks
Thanks Microsoft you helped me a lot. Once again thank you.
it still does not occurs sir is there any other way it worked earlier but now it doesnot please tell me all the settings in that network and sharing centre please sir please
13 people found this reply helpful
Last updated November 28, 2020 Views 140,530 Applies to:
