Microsoft Edge problem 'Hmm, we can’t reach this page
Having installed TH1 I find that Edge can only connect to one of my usual start-up URL's. The working URL is the Open University login page, https://msds.open.ac.uk/signon/SAMSDefault/SAMS001_Default.aspx the other URL's - https://www.google.co.uk/ and http://www.ebay.co.uk/ both return 'Hmm, we can’t reach this page.' message. I tried just using the working tab, after closing the others, and no matter what URL I insert the result is the 'Hmm, we can’t reach this page.' message. All of these sites work with IE11 so is there a problem with Edge an, if there is, how can I get it to work with all URL's not just the OU?
I found a simple and easy way for the fix ....
1. Go to Network Connections..
2. The go to properties of the adapter.
3. And double Click Internet Protoccol Version 4
4. And use Preffered DNS as 8.8.8.8 and Alternative DNS as 8.8.4.4
This simple way worked for me even in windows 7 ( my previous OS)..
NOw this step Worked on Windows 10 Edge.. :)
944 people found this reply helpful
Last updated November 23, 2020 Views 158,411 Applies to:
