KB4512941 is Live for Release Preview to 18362.325
KB4512941 is Live for Release Preview to 18362.325 with SSU KB4515530
Thanks Johnny. I saw those files in UUPDump when
I went to make my ISO and then forgot about it.
And then didn't see a Tweet about it.
Guilty of the same. Just slipped my mind. First attempt using WU failed. Stuck on the Getting Windows Ready screen. Have to revert to a snapshot and try once more before using Dism.
Almost similar to the 18362.10015 failing with both WU and Dism. Had to create an ISO and do in-place upgrade on test laptop to get there.
Johnny
Down and running. I used WU.
Around computers
since 1952
lacrumb
Two more tries with WU, same failures.
Johnny
I'll check in a few...
Got it to 18362.325 using dism. Just no go from WU in vm.
Johnny
This time it worked for me, mystery continues... ;)
Mystery does indeed continue. Tried in another vm that has never been online, both this and previous vm were updated to .295 offline with same software installed (could be clones). Put this one on RP and it upgraded via WU. Go figure.
On a bright note, this time Dism did work with cab files with a WU fail. Not like our experience with the .10015 CU.
Johnny
Thanks for the update Johnny_55
Downloading now.
Success with this CU install on Hyper-V but I did have to turn it off after the H-V install then start it again to get into Windows desktop.
Last updated November 30, 2019 Views 1,318 Applies to:
