Instructions: Create a bootable ISO file using ESD Image for Windows 10 Build 10049
Please note, only US English is available at this time. I will update this thread with access to other languages. Also note, these links might not be live yet. I am not trying them, because I don't want to eat up my bandwidth by opening the link (metered connection). IE has a tendency to anticipate a download.
If you can't wait on Microsoft to push .ISO files to testers for build 10049, you can create yours now:
Download the desired edition and architecture from the following link:
  • Windows 10 Pro x86 build 10049
  • Windows 10 Pro x64 build 10049
  • Windows 10 Enterprise x86 build 10049
  • Windows 10 Enterprise x64 build 10049
UPDATE: I have decided to retire these links because they are not working. Microsoft is strongly pushing Windows Update for installing build 10049.
The Windows Team is deciding whether to release official ISO files the week of April 12, 2015.
For persons requesting other languages, see the following thread:
I will update this link when they become available.
Download ESD Decrypter 4.7 (esd-decrypter-wimlib-4.7z)
You can use NTLite as an alternative to convert the .ESD file into a .ISO:
https://www.ntlite.com/
Extract esd-decrypter-wimlib-4.7z to a folder.
Put the appropriate .ESD file you downloaded into that same folder.
Right click decrypt file in the same folder and click Run as administrator
Select option 1
Hit Enter
Wait
When complete, burn to a blank DVD or create a bootable copy on a USB thumbdrive.
See article for instructions how to do that.
http://answers.microsoft.com/en-us/insider/wiki/insider_wintp-insider_install/how-to-dual-boot-the-latest-windows-build-with/9695dfc7-1c13-4d8d-b10b-587e78c6ac36
Persons have recommended using Rufus for best results when creating a bootable copy on a USB thumb drive.
None of the 4 links to build 10049 work yet.
Keep trying periodically.
Best,
Andre
twitter/adacosta
groovypost.com
Select option 1
Hit Enter
Wait
Waiting for the spanish version
Try using the Windows 10 ESD DB to locate your language.
Then copy:
http://b1.download.windowsupdate.com/c/updt/2015/03/
adding File_Name followed by Hash.
10049.0.150325-1700.fbl_impressive_CLIENTPRO_RET_x64fre_es-es.esd
105C492C3F763B75E3BB8BF2C0E6082B4DF09A6F
Move .ESD to end of URL
Separate language and hash with underscore
http://b1.download.windowsupdate.com/c/updt/2015/03/10049.0.150325-1700.fbl_impressive_CLIENTPRO_RET_x64fre_es-es_105C492C3F763B75E3BB8BF2C0E6082B4DF09A6F.esd
May work eventually. I'm trying with en-gb
Eric Ible ABC DE FGH IJK etc...
Amerture at work - Please mind the steps!
Doesn't work
I'm trying to download the 10049 esd file for x64 Pro, but that link does not seem to work anymore...
Hi Andre--
What about using this process on the install.esd file that lands in the c:\$Windows.~BT directory ?  It created an .iso file for me called en_windows_10_enterprise_10049_x64_dvd.iso but I am having difficulty creating the bootable USB with rufus-- threw an error twice about not being able to extract from the ISO.
Any thoughts ?
M. Kitty
Try using 7-zip to extract the iso to your flash drive.
I did it the way you are suggesting, but for the Windows 10 Pro Build 10049.  I used the Windows 7 USB DVD Download Tool to create the USB stick from the ISO and it worked to install 10049 on another computer.
Don
2012 Alienware Aurora R4 ALX
Intel i7-3960X, 32GB RAM, 250GB NVMe SSD, NVIDIA GeForce GTX 690
Dear sir,
I found that link service unavailable
Last updated August 14, 2020 Views 26,737 Applies to:
