I have been running 9926 release since it was released and seemed to be having no issues and in fact the Explorer issues seem to have been fixed and the issue with cookies getting blocked seems cured as well (Hurrah).
However today I tried running one of my Hyper-V VMs and discovered that the network adapter was saying that the network cable is disconnected. I checked the Hyper-V switch settings and that appears to be set up OK so why does the guest operating system think a cable's pulled out?
I then checked my other VMs and they are all having the same issue.
Additionally when I tried to save one of my running VMs after hitting this issue I got this error:
So as well as not working properly it seems to also be causing an issue when saving your VM.
Is the answer to create a new instance of the network adapter and disconnect the old one and connect to the new one or will this not work either?
Any help appreciated.
I have reported this through the normal feedback tool as well.
Siv
