HP Bluetooth Mouse X4000b stop working after about 5-10 minutes of no activity
Original title: BT Mouse Sleep?
Using an HP Bluetooth Mouse X4000b with Windows Home Insider Preview Build 10565.  Mouse paired, but stops working after about 5-10 minutes of no activity.  Can not delete it from the Bluetooth devices.  It will re-pair and work again...until I let it sit idle for 5-10 minutes.
Did not have issues in previous build.
Hi Chad,
Thank you for posting your query on Microsoft Community.
Do you get any error message?
I would suggest you to try the following methods and check if the issue persists.
Method 1:
Run the Hardware & Devices troubleshooter and check if it helps.
a) Press Start button from the keyboard.
b) Type “Troubleshooting” in the search bar and press “Enter”.
c) In the “Troubleshooting” window, click on “View All” on the left pane.
d) Click on “Hardware and Devices”.
e) Click on “Advanced” and then click on “Run as Administrator”.
f) Click “Next” and follow the on-screen instructions to complete the troubleshooting process.
If the issue still exists, try the next method.
Method 2: Update Drivers
Refer to the following article and update all the drivers available.
How to: Install and Update drivers in Windows 10
In addition to that, install the Bluetooth driver in compatibility mode with Windows 8.1.
Firstly download the driver from your computer's manufacturer website and then install it.
Refer (Make older programs compatible with this version of Windows)
http://windows.microsoft.com/en-US/windows-8/older-programs-compatible-version-windows
Note: This link also applies to Windows 10.
Let us know if it helps. If you need further assistance, let us know. We will be glad to assist you.
Thank You.
A little joke!!!!
Get a cat to chase it every 5 minutes.
Around computers
since 1952
lacrumb
Since it is a bluetooth mouse, there are no drivers required beyond the Windows bluetooth driver.  I can always get it to work by re-pairing, but then after 5 minutes of inactivity the computer stops "listening" for it.
Hi Chad,
Thank you for getting back and keeping us posted on this query. We apologize for the delay in response.
I suggest you to try uninstalling and re-installing the Bluetooth drivers by following the steps below and check if the issue is resolved.
  1. Connect the mouse to the PC and check if the device is getting detected in the device manager.
  2. To go to device manager, press Windows key + X and click on Device Manager from the options.
  3. Expand the Bluetooth driver.
  4. Right click on the Bluetooth driver and select Uninstall option.
  5. Restart the computer to re-install the driver automatically and check if the changes is effective.
Write back to us if you face further issues, we will be happy to assist.
Last updated July 10, 2021 Views 2,439 Applies to:
