How to run programs using compatibility mode on Windows 11?
How to run programs using compatibility mode on Windows 11? When I go to properties, there is no compatibility tab. I would like to run a program I used to use a lot that only works with Windows 7 compatibility.
*Moved from Windows 11
Have you talked with the makers of the programs and found out if they have updated their drivers?
Around computers
since 1952
lacrumb
Thank you for writing to Microsoft Community Forums.
As rightly said by lacrumb, that you need to check with the Program developer/company support, if they have updated driver.
However, you can try this and check, right click on the setup/app and then select as shown below.
Aditya Roy
Microsoft Community – Moderator
Last updated April 2, 2025 Views 14,056 Applies to:
