Help: (0x80244007)
There were some problems installing updates, but we’ll try again later. If you keep seeing this and want to search the web or contact support for information, this may help: (0x80244007)
Go Settings, Updates, Windows Insider program and pick Fast, Slow, or Release Preview.
Around computers
since 1952
lacrumb
It does give the option....
If I stop Insider Preview builds I get ...
So what to do ?
I have Version 1703 and OS Build 15063.413
I am amazed
In your first screen there was Link a Windows Insider account.  Did you do that?  Required!!!!me as you use to log onto Windows 10.
Around computers
since 1952
lacrumb
In your first screen there was Link a Windows Insider account.  Did you do that? Yes screen saved the area of my Windows insider account
I have lots of accounts... I am log into with the administer account.. Here is some of the accounts I have
I cannot change the area "What pace do you want to get new  builds?"
<Removed PII>
It must be the same  account you signed up as an Insider and that you use to log on to Windows 10.  It is your Microsoft account.
Around computers
since 1952
lacrumb
I sign in the administration account *** Email address is removed for privacy ***
I will check signing in email is used with INSIDER account
Ian B Hall
I signed in with  the administration account *** Email address is removed for privacy ***
I will check signing in email is used with INSIDER account...
Which to choose??
Ian B Hall
Did you use your Microsoft account to sign up for Insider and is it the same one you use to log on to Windows 10?
Around computers
since 1952
lacrumb
Solved...sign into with the insider account.....Thanks
Last updated February 2, 2021 Views 163 Applies to:
