ESRV.EXE Application Error (0xc0000142)
I had this Minor thing showing up when I start up after I login.
It comes up as
"ESRV.EXE - Application Error"
"The application was unable to start correctly (0xc0000142). Click OK to close the application"
I have no idea what application it could be?
Can someone help in order to get rid of this error?
***Post moved by the moderator to the appropriate forum category.***
Please try this:
  1. Go to Control Panel (accessible by right clicking your Start Menu button if you are not on the Creators Update, if you are, type Control Panel into Cortana Search)
  2. Open Programs and Features.
  3. Look for Intel Driver Update Utility, if you find it, uninstall it
  4. Reboot
___________________________________________________________________
Power to the Developer!
MSI GV72 - 17.3", i7-8750H (Hex Core), 32GB DDR4, 4GB GeForce GTX 1050 Ti, 256GB NVMe M2, 2TB HDD
2136 people found this reply helpful
Last updated May 12, 2024 Views 178,153 Applies to:
